It is rather unfortunate, the lax state of tarrifs and finacial regulation/enforcement.
But same as you, most of the parts that I wind up needing, the dealer has them, or they get them very quickly. Some are pricey. Some are not. Bushings continue to be a really strange one for me; they are either dirt cheap, or hideously expensive. Depends on the source/volume produced. I usually make my own; however IH used some brass lined/steel shelled bushing here and there (with grease pockets), which I cannot source, because of wall thickness and size limitations. Oh well, I suppose!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
