Re: Farmall H Power Coupling
Posted by matt1983 on August 04, 2011 at 13:04:58 from (71.234.106.161):
In Reply to: Farmall H Power Coupling posted by matt1983 on July 24, 2011 at 17:59:13:
Well I changed the coupling and it didnt fix the rattling. I then removed the pump and that didnt help. The rattling stops when you push in on the clutch, so I took the input shaft out of the transmission. The main bearing seems fine and the inner shaft bearing seems fine too but then I noticed that the inside of the gear seemed to be rubbed pretty bad by the inner sealed bearing. If anyone understands what I'm saying lol, do you think this would cause the rattling noise?
