Re: Farmall H Tranny noise
Posted by D Slater on August 04, 2011 at 18:18:24 from (184.15.12.187):
In Reply to: Re: Farmall H Tranny noise posted by matt1983 on August 04, 2011 at 15:26:54:
When the clutch is engaged the clutch shaft pilot bearing, clutch plate and crankshaft are all turning the same speed as a unit. So probably not the problem. Also the clutch release bearing wouldn't be turning unless out of adjustment. When in neutral clutch engaged the only parts moving at transmission is the input shaft and bearings. Main shaft pilot bearing. Constant mesh gears. Bearings front and rear of countershaft or lower transmission shaft. Second gear on lower transmission shaft turning reverse idler gear. Since you can't try the 5th gear you may try reaching in the hole input shaft was removed from and turning the lower shaft by hand and listen. Also the pto could be engaged and the lower shaft spun from it. Sometimes a worn reverse idler gear shaft or bushings will make a rattle noise. also a chiped tooth on reverse idler gear or its drive gear. You should be able to look at all teeth on constant mesh. Would make sure its not the main shaft pilot bearing first.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
