Posted by CNKS on August 06, 2011 at 18:02:34 from (216.144.104.128):
In Reply to: H engine rebuild posted by PaulGinMN on August 06, 2011 at 16:49:11:
If you have the engine torn down, take the crank to a machinest and see if it needs grinding and the proper size bearings, it doesn't cost that much more.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
