Re: 240 U won't start.
Posted by K-Mo on August 08, 2011 at 10:58:19 from (67.55.164.5):
In Reply to: 240 U won't start. posted by Scotmick on August 08, 2011 at 06:36:52:
Is your 240U 6 volt or 12 volt? If 6 volt it would be positive ground. Other than the battery, check the connections on your coil. The coil terminal to the distributor should agree with the battery ground. If positive ground, "+" on the coil goes to the distributor. If negative ground, "-" on the coil goes to the distributor.
You may want to check the timing. Worn teeth on the distributor drive or sheared or missing pin in the drive gear could cause the type of problem you are having.
