240 U won't start.
Posted by Scotmick on August 08, 2011 at 06:36:52 from (69.124.249.36):
I have a 240 U that won't start. Last week I had a backfire problem, cleaned out the fuel line and it started without backfiring. I ran it for about 45 minutes and parked it. I went back a couple of hours later and it wouldn't start and hasn't started since. I had the starter rebuilt, changed the coil, checked the points and still no spark at the plugs. I tried starting fluid in the cylinders, charged the battery overnight, checked all the wiring and still no start. Now, the good part. I swear that this tractor was negative ground. Checking the manual I have, it said it should be positive ground. With a Mechanic friend of mine, we replaced the battery and coil again, switched it to positive ground and still no spark at the plugs. No Mechanic now, I'm on my own and I need HELP!
Thanks, Don
