First off I agree with Ol Bob there below. That being said, Id feel more comfy if I actually knew the coils primary winding resistance as measured between its little + and -terminals. If its in the vicinity of at least 2.5 prefferred 3 and over ohms, Id say it should be suitable for 12 volts no ballast required. Some lay persons call those "internally ballasted" or with internal resistor (which isnt so, see
HOWEVER if its less then 2.5 ohms, especially if its more like 1.5 THEN ID CALL THAT A 6 VOLT COIL OR "12 Volts for use with or requires external ballast" and Id expect it to overheat plus the points burn up quickly..
The other possibility is if the coil is only marginally suitable for 12 volts (say its internal primary resistance is 2.5 ohms) and the alternator is taking the battery up to over 14.8 volts THEN THE COIL MIGHT OVERHEAT
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
