Posted by Yooper Farmall on August 08, 2011 at 08:31:33 from (141.210.112.16):
Have a rebuilt engine and carb. Was on an hour long tractor drive and it started running badly. I let it cool down and ended up plowing for about 30 minutes when it quit. I put in a new coil and it started up just fine. Weeks later I had it running full throttle, after a couple of hours of running just fine it just quit. Pulled the coil wire, dead and the coil was very hot. Put on a new coil and it started right up.
It has a 12 volt converstion, with 38amp alternator with internal regulator. The first coil was 12v with an external resistor. The second coil was 12v with an internal resistor.
Question: Is there anything with the electrical system that might be cooking my coils, or did I just happen to get a couple bad coils in a row?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
