Re: 240 U won't start.
Posted by Scotmick on August 09, 2011 at 08:18:39 from (69.124.249.36):
In Reply to: 240 U won't start. posted by Scotmick on August 08, 2011 at 06:36:52:
Tuesday Morning update. I have 12.6 volts going into the coil, but not out. I tried both positive ground and negative ground. Same thing. I installed another new coil, same thing on positive and negative grounds. Voltage going in, but about .6 volt coming out. What I really need is a real detailed wiring diagram of the starting system; the one I have is a very simple diagram (with no expected voltage readings anywhere) in a photocopy of the 12-29-59-5B # 1 014 140 R1, Operator's Manual that I bought on eBay along with a photocopy of the Preventive Maintenance Manual which has NO diagrams. I've searched the Internet to no avail. Any suggestions? I really have to get this tractor running again.
Thanks, Don
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
