Posted by Andrew Z on August 10, 2011 at 16:48:24 from (64.252.3.99):
In Reply to: BRAKES ON MY SC posted by RICK IN VERMONT on August 10, 2011 at 15:45:39:
I would say you need to check a few things at least, first is a set of disk's, a complete set is around 60 bucks. Second the ball sockets that are up against the pedal, this is on the adjusting bolt, those will hang up in the pedal and cause binding. Third you need to look at all the braking surfaces and make sure there clean and have a good surface on the no rust, pitting, oil etc. Forth make sure the ball and ramps are in good conditon, this is inside of the brake actuator. Make sure the springs on the actuator are in good shape as well, no broken or fit loose to the actuator. I would look at the first two things that i spoke though.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
