Re: Help me find an engine kit... Pretty Please!!
Posted by El Toro on August 10, 2011 at 17:06:16 from (108.15.86.54):
In Reply to: Help me find an engine kit... Pretty Please!! posted by GRAPE-DRANK on August 10, 2011 at 14:33:56:
You need to measure that area from the top of the block to the area where your seals (doughnuts) are installed. You can probably only use sleeves that measure 6-7/8" in length
and measure 3-5/16" in diameter at the seal. You should be able to get an overbore sleeve kit that will boost the cid 123 cubic inches.
Had you used the 354898R1 block used on the late Super A's and Super C's you could've used 3.250" sleeve kits to give you 133cid. These sleeves measure 7-1/32" in length and measure 3-7/16" at the seal in diameter. Hal
