1486 questions
Posted by GRB54 on August 10, 2011 at 19:34:41 from (198.228.197.236):
Just purchased a 1980 1486- had a 1466 but wanted a factory cab. Have a couple of questions I would like help with:
None of the lights work except the two rear flood lights- checked the fuses and they tested Ok- any quick place to check before starting to look at the whole harness?
How does one get a SMV to stick to the fuel tank- cleaned the tank with simple green and then acetone but the adhesive SMV won't stick- what is the trick?
Thanks in advance.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
