Re: 1486 questions
Posted by pete 23 on August 10, 2011 at 19:44:08 from (74.32.234.149):
In Reply to: 1486 questions posted by GRB54 on August 10, 2011 at 19:34:41:
About the only common problem area for the lights on 86 series is the fuse holder itself. They make poor connection, get hot and then don't make any connection. Check to see if you have power on both end of the fuse holder with fuse installed. Have replaced a ton of those fuse holders over the years.Other than that it could be any connection or series of connections.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
