Re: Magneto
Posted by scatter on August 11, 2011 at 06:39:36 from (67.142.168.23):
In Reply to: Re: Magneto posted by Nebraska Cowman on August 11, 2011 at 06:33:55:
So, if I set the engine at tdc. and have the mag ready to trip on number one right away, it should start? If I'm able to start it, do I move the mag while the engine is running to fine tune it like a distributor? Thanks.
