Re: Another Cub Won't Start CSC
Posted by El Toro on August 13, 2011 at 05:30:54 from (108.15.86.54):
In Reply to: Another Cub Won't Start CSC posted by ccaissie on August 13, 2011 at 05:08:59:
You probably should check your float setting to make sure there's no dirt under the needle valve and your float level isn't set too high. Recheck your valve setting to make they're set at .013"cold. Hal
