Another Cub Won't Start CSC
Posted by ccaissie on August 13, 2011 at 05:08:59 from (72.95.101.67):
Posted earlier, after 1959 cub rebuild, and after installing new carb, displays same symptoms.
Plugs get wet, after occasional sputters. Sometimes runs on a couple cylinders. Sometimes it runs well for a few seconds, i.e. hits on most cylinders. Mostly it floods.
Obviously, engine integrity is ok, and I get reliable spark when checking plugs.
I'm going to r&r the plugs, points, condenser. Had asked earlier if my cranking speed could be doing it (ignition on 6 volt, starter motor on 12), but cranking speed is under 1800rpm, so that doesn't make sense.
Help! This is going on too long!
