10-20 gas pooling in carb
Posted by fordpower30 on August 14, 2011 at 08:58:57 from (97.107.61.203):
Hello,
I have a "29 10-20. starts on a dime pull starting, won"t start off the crank.
I found the gas seems to pool at the bottom of the carb. is there channels or ports in the manifold that could be plugged? the jet inside the throttle is ok. Any help is greatly appreciated. Tyler Martin
