Re: 10-20 gas pooling in carb
Posted by Tom Fleming on August 14, 2011 at 13:29:44 from (67.20.249.95):
In Reply to: 10-20 gas pooling in carb posted by fordpower30 on August 14, 2011 at 08:58:57:
if everything is right, these old girls just need to "hit" once, and off they go. What crank starting procedure are you using? is it similar to the following:
1.) With spark off, choke on, and 1/3 throttle. Give it 2 complete cranks.
2.) advance spark 1/3 of it's travel to full advance. Still on full choke. Leave throttle at 1/3. start around the 3 - 4 oclock position. stick thumb out like you are going to hitch hike. give the crank a good, speedy 1/2 spin, cupping the handle with your thumb alongside NOT OVER!
3.) If it doesn't fire in 1-2 cranks, back choke off a tad, maybe 3/4 to 1/2.
crank again. If it doesn't fire this time, something is not working correctly.
PS. is there plenty of suction at the carb? Is your air cleaner clean? Good air flow?
This post was edited by Tom Fleming at 13:30:55 08/14/11.
