Re: Farmall M No Compression
Posted by El Toro on August 14, 2011 at 13:20:54 from (108.15.86.54):
In Reply to: Farmall M No Compression posted by John Lundberg on August 14, 2011 at 12:28:54:
Pull the valve cover and see if the rocker arms are moving when cranking over the engine. The camshaft or timing gear may have failed. I think I've read on this forum about the hydraulic pumps on the M's causing timing gear failure. Probably need to do what redih suggested. Still going to involve a good bit of work. Hal
