Posted by BoonvilleKid on August 15, 2011 at 12:46:11 from (205.201.107.156):
This is the first Farmall C I have worked on and I"ve found a lot of difference on several items between a Super C and a C. For instance the brakes. The previous owner apparently never believed in any maintenance and rode the brake bands down to where even the rivets were gone. I"ve turned down the "drums" installed new bands. I marked the arm against the shaft and reinstalled it in the same grove. Now, I can"t figure out how to adjust the bands. I have no manual. When I get the bands as tight as possible the pedal is still very loose. But, the spring device cannot be turned w/o turning the whole device which means removal of the pin. Tightening up the device means that the pin cannot be re-installed due to mis-alignment. Help me if you can, I"m lost.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
