Re: 1949 Farmall C
Posted by BoonvilleKid on August 16, 2011 at 10:20:32 from (205.201.107.156):
In Reply to: 1949 Farmall C posted by BoonvilleKid on August 15, 2011 at 12:46:11:
I think I found the problem; Due to years of rust between the washer and the spring body, then being covered by new paint, it was next to impossible to turn the nut independently of the spring body. Soaking in paint remover and then Blaster solved that problem. But, I still can't understand why Farmall put a nut on that adjustment bolt that only has two flats. That makes it almost impossible to turn the wrench without hitting the sides of the spring body. ?
