Re: Clutch stuck on Farmall C
Posted by Janicholson on August 15, 2011 at 14:47:50 from (199.17.6.77):
In Reply to: Clutch stuck on Farmall C posted by CT8N on August 15, 2011 at 14:34:57:
Drive it in 3dr gear and quickly apply the brakes. Be careful!
The clutch is nested down inside the flywheel, and can't be squirted very well.
Putting it in high gear, and bumping the starter with the brakes on, and the ignition OFF can also snap them loose. Other than that it is a Split of the trans from the engine. Jim
