Re: Clutch stuck on Farmall C
Posted by JRSutton on August 15, 2011 at 16:14:35 from (75.130.109.233):
In Reply to: Re: Clutch stuck on Farmall C posted by Janicholson on August 15, 2011 at 14:47:50:
Can be hard/dangerous to start in gear!
If you have somebody with another tractor, you could try having them tow you with clutch in, and in high gear.
Just that initial pull might be enough to pop it. if not, keep going, and try the brakes (and be sure you're pushing the cluth in).
