Hi Dean: I have been plowing some virgin sod each of the last 4 years.( It was used as pasture.) I also had a Farmall 350 rowcrop. Only difference is the plow. I first used an IH 2x14 trailing plow, since I had it. I just happened to have rear wheels set at 64 inch center to center. 12.4X38 Firestone Field & Road. Power was way more then needed to pull that little plow in fairly good black soil. The biggest problem I had was not using the right TYPE of plow Moldboard for heavy sod. In my case the root system was deeper the any I'd seen before. I ended up going about 9 inches deep. I was told to find a plow with a much more curved moldboard, which will Roll-Over that heavy dense sod. Found an older Case 2 bottom, built heavy and had all steel wheels, and a well CURVED Moldboards... Bingo... sucess..!! The right type plow made all the difference in the world. Could have used any color tractor, rowcrop or utility. I have pictures if needed.. Ugly results because of wrong type moldboard may be your problem too?? Good luck. ag
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
