Setting up Farmall 350 to plow?
Posted by Dean Olson on August 15, 2011 at 18:49:05 from (98.196.66.64):
I'm going to get my Farmall 350 row crop set up to handle a 2-16" fast hitch plow. I going to try to bust some sod in a pasture that hasn't ever been turned that we know of. I tried this on another pasture with my Super C and C20 plow. I got it done but is was ugly. The SC just isn't big enough.
Tires are 12.4X38" 8 ply with about 50% tread.
How much weight can or should I add to the rear? I can fill the tires and have 5 sets of the 1 piece 140lb. IH weights.
I have a set of frame weights that will also go on. Will I need more that that on the front?
I know the right rear tire has to be set in. Any insight on that configuration would save me some trial and error.
Currently the cast center is dished out and as close to the axle as it can get. Rim is on the inside bevel now.
Thanks in advance.
