I think what agpilot is talking about is that high speed moldboards may not work as well in sod as standard moldboards. All the Fast-Hitch plows I have seen did have high speed, but it's possible some did not. Our Super C 2x14 plow had the extentions or "wings" on the end of the high speed moldboards which may help roll over the sod. The high speed moldboards are meant to be pulled at a higher speed so the speed helps roll the dirt over more. With a strong 350 and 2x16", you should be able to pull fast enough to do a decent job. Any bigger than that, you probably won't be able to pull fast enough to do more than set the sod on edge.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
