Re: Farmall Super M Hydraulics
Posted by jtbartlett on August 16, 2011 at 06:11:14 from (71.169.156.148):
In Reply to: Re: Farmall Super M Hydraulics posted by Wardner on August 15, 2011 at 22:25:39:
Thanks Wardner. I guess I'm not clear with the terms liftall and live power. This tractor (My first one) came from the factory with no liftall belly pump. Just a plate with the belly hook. The IH live power pump plumbs to under the gas tank. There is no obvious plumbing from the resevoir under the tank to the liftall resevoir. I'm not sure why the liftall kickout lever would connect to the live power resevoir since there's no liftall whatsoever. Does this control lever select 'all' hydraulics to the gresen valve bank?I'm assuming there's an 'all' or 'no' selector in the live power resevoir to the valves?
Also, on the left side of the resevoir there are 2 90 street elbows. I believe they are both returns however I only see the need to use one. Do people use the second return to plumb to the liftall resevoir when there is one to use?
Thanks a lot for the help. I'm learning a bit as I'm going through this.
