Re: Farmall Super M Hydraulics
Posted by Wardner on August 15, 2011 at 22:25:39 from (4.154.237.114):
In Reply to: Re: Farmall Super M Hydraulics posted by Wardner on August 15, 2011 at 22:06:02:
I should also add that the kickout of Liftall system is designed to protect the live pump and driving components. When it is locked open with the rotating lock tang, there is some possibility that those pump components and gear train could be stressed with an overload such as a deadhead when the hydraulic cylinder reaches the end of its stroke.
To counter that condition, the integral Gresen relief valve should be set at around 1200 PSI. It is probably set at the factory for 2000-2500 PSI. There are probably some people who don't bother to lower the remote valve pressure relief and get away with it. Chances are that their pumps internally leak enough so they cannot develop modern high pressures.
