farmall m hydraulics
Posted by leonlss on August 16, 2011 at 18:18:03 from (206.51.197.150):
I have a farmall M with belly pump and have added a duall loader. The tractor handles the loader fine but fluid
capacity is to low as fluid comes out the fill tube when I lower the loader. The loader has a oil tank in the frame. Can someone tell me how to run the lines to utilize this tank to house the needed oil volume ?
