Re: farmall m hydraulics
Posted by Janicholson on August 16, 2011 at 19:46:48 from (96.24.99.126):
In Reply to: farmall m hydraulics posted by leonlss on August 16, 2011 at 18:18:03:
Putting a good sized (medium pressure) hose from the bottom of the loader reservoir, to a "T" in the drain of the Liftall, Will allow the loader's reservoir to parallel the tractors.
If the loader reservoir is not filled completely it will not gush out.
If the loader cylinders are hooked up as single acting, lift only, but are fitted with vents on the top ports, lines can be attached to these, and "T"ed into the reservoir drain of the Lift all. Best of luck, Jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
