Re: Engine rev after carb overhaul
Posted by truckerlary on August 16, 2011 at 18:20:53 from (12.19.152.194):
In Reply to: Engine rev after carb overhaul posted by Sean0918 on August 16, 2011 at 17:36:21:
When you reassembled the carb to the shaft coming from the governor it sounds like you didn't get the tang on the shaft into the slot on the carb.
