Engine rev after carb overhaul
Posted by Sean0918 on August 16, 2011 at 17:36:21 from (74.79.254.42):
Please help! I took the carb off of my 300 utility today. I replaced the float valve and ever so slightly bent the float so that it measured the correct distance. I reassembled the whole thing and started it up. The engine revs at a high RPM. Closing the throttle cuts it down a little but it still revs way too high. Backing out the idle screw does nothing. I feel like I screwed something up in the governor but I don"t know. The only thing I could think of would be if I didn"t connect the throttle arm to the governor correctly. but I move the throttle and everything seems to be fine in the governor. I am at a total loss. Please help! thanks in advance!!
