block water headers
Posted by cushman on August 16, 2011 at 18:31:40 from (71.51.118.6):
After playing with my JD G and GP for 24 years,I bought a 400d and found the cooling system very dirty.I removed the rear water header which has part of the header rusted away.I went to my local salvage yard and found thin steel and 1/4 inch steel plates.which should I use and why do they direct water down away from the head?
