Posted by D Slater on August 16, 2011 at 18:57:08 from (184.15.0.80):
In Reply to: block water headers posted by cushman on August 16, 2011 at 18:31:40:
They dirrect the coolant down and around the lower cylinders and then the coolant rises up to the head. Last ones IH used for the headers was the thick ones. Around half the 400D tractors came with the thin ones before change over. Some MD used a shorter baffle inside the cover, so if using a thin cover get the same length baffle as the 400. When using the thick cover some engines that had the thin covers need the cross shaft bracket ground for clearance.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
