Re: Engine rev after carb overhaul
Posted by truckerlary on August 16, 2011 at 18:38:45 from (12.19.152.194):
In Reply to: Engine rev after carb overhaul posted by Sean0918 on August 16, 2011 at 17:36:21:
You just have to look in as you're putting it together. When you get it together make sure it stays as it'll jump out of the slot if you let it come apart just a little. good luck
