Re: Farmall M removing pully's in the front
Posted by Janicholson on August 16, 2011 at 20:52:23 from (96.24.99.126):
In Reply to: Re: Farmall M removing pully's in the front posted by John Lundberg on August 16, 2011 at 20:16:47:
Generally the front of the tractor is removed to access the gears/pulley etc. IIRC the pulley will not come off far enough to clear the shaft W/O hitting the lower bolster. Getting the front off starts with removing the steering shaft from the gear box. Jim
