Re: Victory! (carb/governor problems)
Posted by Janicholson on August 19, 2011 at 09:23:06 from (199.17.6.77):
In Reply to: Re: Victory! (carb/governor problems) posted by Owen Aaland on August 19, 2011 at 08:28:11:
Correct!
Same reason a tire valve will get cold when the air rushes out.
Same reason a spray can valve gets cold.
Same reason (but in reverse) when a hand tire pump gets hot at the bottom.
Cars and modern vehicles have heat stoves or intake heaters to eliminate carb freezing. It can get to the point that internal ice builds up acting like a choke plate. it will run way rich, and stall. The change happened about the mid 60s for many cars. Some tractors have had a stove system hooked between the Muffler surround, and the intake to prevent icing. Jim
