Re: Farmall M Gears in front not turning
Posted by Janicholson on August 20, 2011 at 11:28:41 from (199.17.6.160):
In Reply to: Re: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 11:25:29:
With the pan off look at the crank while someone bumps the starter. If nothing turns that is visible, I bet on flywheel bolts shearing off, or crank broken at the rear main. Do not just spin the engine if it is broken do not make it worse, See my comments above. Jim
