Re: H starting problem
Posted by Wyokid on August 20, 2011 at 17:02:51 from (72.36.61.157):
In Reply to: Re: H starting problem posted by Janicholson on August 20, 2011 at 15:41:44:
Still have spark as and after it shuts off so guess it's carb related. I'll pull it off and check float setting and make sure all the passages are clear.
Thanks for the assistance.
