Re: H starting problem
Posted by Janicholson on August 20, 2011 at 15:41:44 from (67.72.98.45):
In Reply to: Re: H starting problem posted by Wyokid on August 20, 2011 at 15:35:41:
With the Mag #1 plug wire attached to a spair sparkplug, ground the plug and shade it from direct light so as to be able to see it. Watch the plug as the engine is started. If the spark quits, you have a direction to search. If it still sparks, it may be in that carb. There is a screen in the inlet to the carb fitting that can plug up radically and isn't obvious. Jim
