Re: Manifold Leak?
Posted by Red Relic on August 15, 2000 at 19:07:49 from (63.11.80.246):
In Reply to: Manifold Leak? posted by Patrick Graham on August 15, 2000 at 18:34:01:
Maybe the manifold...maybe not.
1. Does it have good compression? You may want to check this first...the best tune up in the world won't make up for lack of compression.
2. If you have good compression, do you have good spark at the plugs?? If not, check your plugs, wires, cap, rotor, points, condensor, and coil.
3. All the above good, go through the fuel system. You say you have good fuel. If you have an air leak on the intake side, you could be running way lean, which would explain the rough running.
I have learned through trial and error to check things in this order. You can check in any order, but don't overlook anything.
Post A Followup
: Re: Re: Manifold Leak?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
