Re: Rust in tank
Posted by Jim Becker on August 22, 2011 at 08:25:49 from (173.57.144.251):
In Reply to: Rust in tank posted by kopeck on August 21, 2011 at 18:21:34:
I have to lean the same way CNKS is on this. If you really only have "a section in the rear of the tank that just had a strip of rust" and no big chunks sloshing around, I would rinse it out to remove any loose rust and use it. It will be years before it gives you more trouble. In the meanwhile, that is what the sediment bowl is for.
