Re: Rust in tank
Posted by rustyfarmall on August 22, 2011 at 08:46:29 from (216.248.71.224):
In Reply to: Rust in tank posted by Jim Becker on August 22, 2011 at 08:25:49:
Make that 3 of us that agree, and I'm here to tell you that the sediment bowl will catch every bit of the rust, even from a severely rusted tank, and none of it will ever get as far as the carburetor. That red-cote stuff or any other brand of fuel tank liner is way over-rated. You don't need it.
