Bring No1 piston near the radiator to tdc on the compression stroke. Remove the sparkplug and hold your thumb over the plug hole until you feel pressure & have a helper to hand crank the engine. Once you feel pressure drop a long plastic straw on top of the piston and you watch the straw rise while the helper slowly cranks the engine. When the straw quits rising your No1 piston should be at tdc on the compression stroke and both valves should be closed on that cylinder. Pull the distributor cap and see where your rotor is pointing. Should be at the No1 plug tower which is about 2 o'clock. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
