It is kind of strange sometimes I get 30 on the first crank and if I keep cranking they may get to almost 60. I kind of questioned the tester so I took it over to my 100 and tested a hole and it popped to 90 right away. I afjusted the valves 15 cold. I may try and back them off to 17 and see if it makes a difference but I suspect the valves and I was even thinking like someone suggested that the cam is installed off time but it does not look like it has been apart but then again has not run in a couple of years.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
