Re: 450D Power Steering one more time...
Posted by Janicholson on August 24, 2011 at 19:03:08 from (96.24.99.126):
In Reply to: 450D Power Steering one more time... posted by labman98 on August 24, 2011 at 18:48:01:
The standard set of valves on a tractor with no PS will not have the priority valve built in. The valve you need (if you want to have it like stock) is from a tractor with PS. I think it is the inner control valve. A seperate pump can be used driven by the engine and it will be reliable and pretty easy. A non stock priority valve can also be purchased (Surplus Center has them reasonably priced). The system is not pressurized unless a valve is operated when it is the way you describe. Jim
