Posted by gene bender on August 25, 2011 at 10:39:20 from (207.177.56.151):
In Reply to: H Charging posted by BTaylor on August 25, 2011 at 06:51:36:
Yes you can still get a cut-out they are small like the ones used on ACs. There are two regs made for the I-H charging systems did you have it hooked up for pos gnd it should have been marked. Some of the regs will still use the control for hicharge as i have one and it has worked for at least 25yrs. Maybe you lite control box isnt grounded good as the reg and the gen all need chassis ground which should be pos if you have the correct gen on the H.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
