H Charging
Posted by BTaylor on August 25, 2011 at 06:51:36 from (34.254.119.221):
I used the link from Bob to re-wire my H. I installed a new 6 volt regulator. It was charging continuosly for a while, then stopped charging altogether. The points on the regulator are pretty fryed, and this happened in a really short time. Any ideas on what i did wrong? Also, the light switch had no affect on the system in regards to the low and high charging positions. I know that was designed for a cut out switch, but not sure if should affect a regulator. And, are cut out switches still available?
