Re: H Charging
Posted by John T on August 25, 2011 at 12:29:41 from (63.252.228.254):
In Reply to: H Charging posted by BTaylor on August 25, 2011 at 06:51:36:
If then tractor was started and the genny was polarized incorrectly such that it was opposite from the battery, that can fry relay contact points.
You can use EITHER a Cutout Relay or a Voltage Regulator if wired correct.
You also should use a VR thats correct for your tractor i.e. if its Pos ground then use a VR suitable for Pos ground 0
If its a relay FLD on genny wires to the LHBD light switch but if its a VR FLD wires to the VR NOT to the switch
John T
