Re: Better 6 volt lighting
Posted by scatter on August 25, 2011 at 17:17:13 from (67.142.168.26):
In Reply to: Re: Better 6 volt lighting posted by Janicholson on August 25, 2011 at 17:03:04:
Thanks. I don't have the original light switch. I had a friend of mine that is a tin knocker make me a very nice replacement box. The light switch is just on or off, no dimmer. I also have an inline charge switch on it so I can kill the link between the voltage regulator and battery when tractor is not running. Plus, I wired the ground wire from the mag to a switch to kill the engine. I have a local shop that works on generators, maybe I can ask them about improved output for the generator. It's really not that big of a deal, it would just be nice. I'll check out the link you sent. Thanks, Steve.
